はじめに
This guide will show how to replace the motherboard of your OnePlus 6T. Make sure to use the correct tools and to be careful after removing the back cover of the device.
必要な工具と部品
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
この手順で使用する道具:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
3 の人々がこのガイドを完成させました。
