メインコンテンツにスキップ
Olympus Stylus 410 Battery Cover Replacement
必要な工具と部品
  1. Olympus Stylus 410 Battery Cover Replacement, Slider: 手順 1、 1の画像 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Battery Cover Replacement: 手順 2、 1の画像 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Battery Cover Replacement: 手順 3、 1の画像 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Battery Cover Replacement: 手順 4、 1の画像 1
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 Battery Cover Replacement, Outer Case: 手順 5、 3の画像 1 Olympus Stylus 410 Battery Cover Replacement, Outer Case: 手順 5、 3の画像 2 Olympus Stylus 410 Battery Cover Replacement, Outer Case: 手順 5、 3の画像 3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 Battery Cover Replacement: 手順 6、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 6、 2の画像 2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 Battery Cover Replacement: 手順 7、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 7、 2の画像 2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 Battery Cover Replacement: 手順 8、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 8、 2の画像 2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 Battery Cover Replacement: 手順 9、 3の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 9、 3の画像 2 Olympus Stylus 410 Battery Cover Replacement: 手順 9、 3の画像 3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 Battery Cover Replacement: 手順 10、 1の画像 1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 Battery Cover Replacement: 手順 11、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 11、 2の画像 2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 Battery Cover Replacement, Battery Cover: 手順 12、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement, Battery Cover: 手順 12、 2の画像 2
    • Open the battery cover and lift it up and off of back camera case.
  13. Olympus Stylus 410 Battery Cover Replacement: 手順 13、 3の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 13、 3の画像 2 Olympus Stylus 410 Battery Cover Replacement: 手順 13、 3の画像 3
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  14. Olympus Stylus 410 Battery Cover Replacement: 手順 14、 2の画像 1 Olympus Stylus 410 Battery Cover Replacement: 手順 14、 2の画像 2
    • Slide the metal piece off of the battery cover.
  15. Olympus Stylus 410 Battery Cover Replacement: 手順 15、 1の画像 1
    • This is what the battery cover and back case look like completely disassembled.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Rory Aronson
メンバー登録日: 04/15/10
46 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S6G13
5 メンバー
17のガイドは作成済み
コメント 1 件
i need Battery where i can find it thinks
uae20162017 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,936
