メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Over time, the LCD screen can be damaged. This guide shows the relatively easy process for replacing the display on the Olympus C-765.
パーツ
パーツは指定されていません。
  1. Remove all the screws using your Phillips #00 holding the back plate in place. This includes: On the Back: Unscrew the 4mm screw to the right of the viewfinder. On the Bottom:
    • Remove all the screws using your Phillips #00 holding the back plate in place. This includes:
    • On the Back: Unscrew the 4mm screw to the right of the viewfinder.
    • On the Bottom:
    • Unscrew the 3mm screw in the top left corner.
    • Unscrew the four 3mm screws under the battery cover.
    • On the Right Side: Unscrew the one 3mm screw holding the right-side panel.
    • On the Left Side: Unscrew the two 2mm screws holding the left-side panel.
  2. After you remove the back cover: Gently pull the two ribbon cables out of their sockets.
    • After you remove the back cover:
    • Gently pull the two ribbon cables out of their sockets.
    • Gently disconnect the white cable.
  3. Peel the black tape off the back of the LCD. Using the Phillips #00 remove the four 3mm screws on the LCD bracket. Remove the two 2mm screws from the top of the bracket.
    • Peel the black tape off the back of the LCD.
    • Using the Phillips #00 remove the four 3mm screws on the LCD bracket.
    • Remove the two 2mm screws from the top of the bracket.
    • Use a spudger to pop the LCD screen out of the camera’s backplate.
    • When the bracket comes off, the buttons from the top section may fall out of place. If this happens then put them back in the position they were in.
終わりに
2 の人々がこのガイドを完成させました。
Mason Morgan
メンバー登録日: 2011年04月05日
115 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-33, Maness Spring 2011 Cal Poly, Team 12-33, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G33
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,682
