メインコンテンツにスキップ
Oculus Rift Control Box Motherboard Replacement
必要な工具と部品
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 手順 1、 3の画像 1 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 手順 1、 3の画像 2 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: 手順 1、 3の画像 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift Control Box Motherboard Replacement: 手順 2、 3の画像 1 Oculus Rift Control Box Motherboard Replacement: 手順 2、 3の画像 2 Oculus Rift Control Box Motherboard Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 手順 3、 3の画像 1 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 手順 3、 3の画像 2 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: 手順 3、 3の画像 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift Control Box Motherboard Replacement: 手順 4、 3の画像 1 Oculus Rift Control Box Motherboard Replacement: 手順 4、 3の画像 2 Oculus Rift Control Box Motherboard Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
終わりに
作成者
5人の作成者と共同で作成されました。
Audrey Chan
メンバー登録日: 01/12/15
201 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G5
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,230
