この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If you noticed your volume buttons are not controlling your volume, and you have tried other methods of raising and lowering your volume, this guide will show you how to replace the volume buttons.
必要な工具と部品
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
While using the black plastic spudger tool, slowly lift the tape with your fingers and hold the wires down with the tool.
この手順で使用する道具:Tweezers$4.99
Carefully remove the audio input films for each speaker from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them.
Pull up the white latch on the ZIF connector, which will release the film and allow you to pull it out with tweezers.
Repeat this for both speakers.
Here are the button switches that are pushed for your Volume Control.
This is your power button switch.
ある他の人がこのガイドを完成しました。
