メインコンテンツにスキップ
Nokia XL Dual Sim Front Camera Replacement
必要な工具と部品
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: 手順 1、 1の画像 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: 手順 2、 2の画像 1 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: 手順 2、 2の画像 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: 手順 3、 2の画像 1 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: 手順 3、 2の画像 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 1 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: 手順 4、 3の画像 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Front Camera Replacement, System components: 手順 5、 1の画像 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 1 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 2 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: 手順 6、 3の画像 3
    この手順で使用する道具:
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Shadeed Bilal
メンバー登録日: 09/25/14
231 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G4
3 メンバー
7のガイドは作成済み
1 Guide Comment
merci 1000 fois pour ce cite
zmohye - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 18
今までの合計 1,098
