この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If there are issues with the volume, power, or camera buttons, it could have to do with a faulty ribbon. This guide shows how to replace that.
必要な工具と部品
Use the T5 screwdriver to remove the two 8.6mm long screws, located at the bottom of the phone. (Head size is 2.5mm)
Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
Prerequisite step: Back panel removal
Use the T4 torx screwdriver to remove the 3mm screw (diameter of the head is 1.5mm) fastened to the metal clip, holding the battery in place.
Prerequisite guides: Back panel removal, Battery Removal
Use the plastic opening tool to gently lift up on the connective piece attached to the volume, camera, and power button strip.
Flip the front panel on its side with the strip you are working on facing upward.
Use a spudger tool and starting at the top, gently pry the button sensors up.
Slide the tool underneath the strip and pry up the next button sensor.
Do this down the line until the strip becomes completely detached.
6 の人々がこのガイドを完成させました。
