このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Place the spudger tool or flat plastic tool on top of the ribbon cable to avoid damaging it when prying up on the metal clip.
Use a plastic opening tool, or gently use a small metal flat-head screwdriver to pry up the metal clip. (It is recommended to use a plastic tool; However, if the opening tool does not work or fit into the small opening underneath the clip, use the flat-head.)
この手順は未翻訳です。 翻訳を手伝う。
Flip the front panel on its side with the strip you are working on facing upward.
Use a spudger tool and starting at the top, gently pry the button sensors up.
Slide the tool underneath the strip and pry up the next button sensor.
Do this down the line until the strip becomes completely detached.
6 の人々がこのガイドを完成させました。
