はじめに
Here is a Nokia Lumia 520 with a broken front glass. It is possible to purchase just the glass, but I opted against this. Nokia refers to the front assembly (Glass and Digitizer) as the Touch Window, it is around $10 and it is easy to replace. I previously tried unsuccessfully to separate the digitizer from the glass.
This guide is also applicable to the Nokia 521. The Nokia 521 has a 4th M1.5x3 screw in the lower left corner of the battery compartment, as shown in Step 3.
必要な工具と部品
The damage to the digitizer is clearly visible. Nokia refers to the glass/digitizer combo as the "touch window"
Turn the phone over,
and release the back cover by pushing it off the phone from the top
Use a guitar pick or similar opening tool to unsnap the touch window assembly from the support frame.
This will separate the touch window from the rest of the phone.
The last step is missing. You will have to remove the digitalised from his frame by slightly unstick it all around the frame. Take your time to avoid braking the fragile frame.
They say to separate the screen from the frame you should try to use a hairdryer to heat the adhesive so it comes apart. If you want to buy a new screen & tools, you can try aliexpres but PLEASE remeber to check the reviews and number of orders... This is the one I'm waiting for : http://www.aliexpress.com/item/100-New-O...
Don't mean to sound stupid, but I do not know much about this phone. My screen is slightly cracked and it will not respond to touch, is the cracked screen why? I just bought it and screen got cracked before use. I know several people that have cracked screen and they use their phones. Wanted to know before I bought the replacement.
101 の人々がこのガイドを完成させました。
20 件のコメント
I used a t5 screwdriver and it worked perfectly :D
tnx for the guide!!
ivan coene - 返信
Probably one of the easiest repairs i have ever done, tip pay, an extra few pounds and get the digitizer with the frame.
Hi Adrian, where did you buy the Touch Windows? I asked Nokia but they do not sell it..
Thanks.
Rod
The last and hardest step is missing---separating the digitizer from the surround. They are glued together and you basically have to destroy the glass to get it off. (See the teardown for details.) Other than that, a great guide, thanks.
Well... you're trying to replace the glass in the first place, so it's technically already destroyed.
Also, I broke my Lumia 520 screen and I'm waiting for the replacement screen to arrive. If you use your thumbnail or something very thin but strong, you can separate the glass from the frame without causing more damage to the glass by running it underneath the edges of the glass, all the way around.
Granted, it took a couple of goes to separate them because of the glue, but it did come off without breaking either the frame or the glass.
It looks very workable, but, like Rodolfo, I can not find where to purchase a new Touch Window.
Patrick Kelly July 1 2014
I found a replacement glass for the nokia 520 on ebay. Do you think that will work on the 521 also?
Worked very well am a 70 year old would have been lost without the guide.
Many thanks
Yes, T5 is the one for the back screws. As with comments above, this otherwise useful guide doesn't cover removal of old digitizer from the frame. I would say gentle heat from hairdrier, and prise up corner with a thin plastic-edged tool and run down the sides - carefully! Heat as you go until glass is removed. Old glue can be cleaned off with cotton bud and methylated spirits, which usefully doesn't melt or discolour most plastics. Its worth getting the inside edge even to avoid possibility of cracking new glass when pressed into position. The back of the new digitizer has a film that is pulled off to reveal the adhesive edges. Once it's lined up in the frame from the front, I found it useful to press the the frame home laid flat, screen down, on a table and working round the edge.
This is a good guide. I would just like to add my tip.
Use a hot air gun to separate the screen from the frame. This heats up the glue and makes separation fairly easy.
DON'T FORGET TO MAKE A HARD RESET IF YOUR NEW SCREEN DOESN'T WORK
Link for the manipulation : https://www.youtube.com/watch?v=LtWR6en5...
ADD IT TO THE MANUAL PLEASE
Really awesome guide. I appreciate the time you took to take those shots and put it together; it really cuts down on the time (and guesswork) it takes for me to repair something. One thing -- those are Torx T5 screws, not T4. The T4 bit I was using almost stripped the head of one of the tighter screws as I was trying to remove it.
It's pretty amazing how simple the inside of a phone looks these days.
"The last and hardest step is missing---separating the digitizer from the surround". Joe's comment is true. This step is not there. And in my case, my ebay order did not come with the 'surround'. I had to tear off the old surround and somehow stick into the digitizer. And it worked!
I dont see any reason to seperate front glass from the digitizer frame. Way too much work for few euros to be saved or what ever your currency is. Also if the front glass is cracked you cant be sure if digitizer works fully or you damge it at trying to remove front glass.
Hey there, i have a phone like that but the actual phone screen is frozen and a bit cracked... I took off the protector glass to check if anything was wrong with the protector but there was nothing wrong... Is there any possibility that it could get fixed or work again? Just wondering :)
tori banks - 返信
