メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your tablet microphone is not working at its best, you can replace it easily using this guide. To do so, you will need to disassemble your tablet and use soldering tools.
  1. Look towards the topside of the tablet, where the power button is located.
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely. Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case. Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Remove the tape holding the battery in place. Remove the tape holding the battery in place. Remove the tape holding the battery in place.
    • Remove the tape holding the battery in place.
  4. Insert the flat end of the spudger tool  in the crack beneath the battery. Move the spudger tool carefully side to side to remove the glue that is holding the battery in place. This is a soft battery, so a little bending is expected.
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. After the battery is unglued, locate the cables that connect it to the motherboard.
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Desolder the cables with a soldering iron and use a desoldering braid to remove the solder. Review the Ifixit soldering guide if you need help soldering.
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Remove the black tape covering the cameras power cable. Remove the black tape covering the cameras power cable. Remove the black tape covering the cameras power cable.
    • Remove the black tape covering the cameras power cable.
  8. Use the spudger tool to pry upwards the ZIF connector and release the power cable. Use the spudger tool to pry upwards the ZIF connector and release the power cable.
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard. Using tweezers, carefully grab the front camera and twist slowly. The camera should release easily, do not twist too hard.
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
  10. Locate the microphone's cables in front of the cameras' ZIF connector.
    • Locate the microphone's cables in front of the cameras' ZIF connector.
  11. Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
  12. Use the pointy end of the tweezers to retrieve the microphone from its socket. You can now remove the microphone.
    • Use the pointy end of the tweezers to retrieve the microphone from its socket.
    • You can now remove the microphone.
終わりに
Daniel Gomero
メンバー登録日: 2015年01月21日
954 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015人のメンバー
USFT-BROWN-W15S5G5
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 108
