メインコンテンツにスキップ
Nintendo Wii Remote Front Cover Plate and Batteries Replacement
必要な工具と部品
  1. Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 1 Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 手順 1、 2の画像 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 手順 2、 1の画像 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 手順 3、 1の画像 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 手順 4、 2の画像 1 Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 手順 4、 2の画像 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
終わりに
27 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Emily
メンバー登録日: 04/14/13
1,170 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G44
4 メンバー
21のガイドは作成済み
4 件のコメント
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - 返信
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - 返信
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - 返信
コメントを追加
統計データ:
過去 24時間: 95
過去 7 日: 340
過去 30 日: 1,417
今までの合計 82,163
