はじめに
This guide will show you the steps on installing the shoulder buttons. This will be helpful if the shoulder buttons are not working properly.
Only replace the faulty shoulder button(s).
必要な工具と部品
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
この手順で使用する道具:Tweezers$4.99
Using tweezers remove the three grey button pads from the motherboard.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
5 の人々がこのガイドを完成させました。
1件のガイドコメント
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
