メインコンテンツにスキップ
Nintendo WaveBird Wireless Controller C-Stick Replacement
必要な工具と部品
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 手順 1、 2の画像 1 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 手順 1、 2の画像 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: 手順 2、 1の画像 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 手順 3、 2の画像 1 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 手順 3、 2の画像 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: 手順 4、 2の画像 1 Nintendo WaveBird Wireless Controller C-Stick Replacement: 手順 4、 2の画像 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 手順 5、 3の画像 1 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 手順 5、 3の画像 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 手順 6、 2の画像 1 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 手順 6、 2の画像 2
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Garrett Leung
メンバー登録日: 04/16/13
979 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 25
今までの合計 2,686
