はじめに
If your game is not responding to the joystick on your Nintendo NES Advantage Model NES-026 game controller, the joystick's ball sensor may be clogged by a foreign object or the joystick's spring may be weak.
This guide is about removing the joystick panel. After the joystick panel is removed, you will be able to see the joystick's ball sensor and spring.
必要な工具と部品
Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
もう少しです!
終わりに
