メインコンテンツにスキップ
Nintendo GameCube Controller Buttons Replacement
必要な工具と部品
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: 手順 1、 1の画像 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Buttons Replacement: 手順 2、 1の画像 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - 返信
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: 手順 3、 2の画像 1 Nintendo GameCube Controller Buttons Replacement, Z Button: 手順 3、 2の画像 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - 返信
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: 手順 4、 1の画像 1
    • Carefully unhook the cable that is looped around the peg.
    Um can soneone explain the peg and cable part? I dont understand it...
    Tyler Goamez - 返信
    I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
    My1 -
  5. Nintendo GameCube Controller Buttons Replacement: 手順 5、 1の画像 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: 手順 6、 2の画像 1 Nintendo GameCube Controller Buttons Replacement, Buttons: 手順 6、 2の画像 2
    • Remove the rubber backing that covers the buttons.
  7. Nintendo GameCube Controller Buttons Replacement: 手順 7、 3の画像 1 Nintendo GameCube Controller Buttons Replacement: 手順 7、 3の画像 2 Nintendo GameCube Controller Buttons Replacement: 手順 7、 3の画像 3
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
終わりに
18 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Sean Michel
メンバー登録日: 01/14/13
2,496 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G44
4 メンバー
26のガイドは作成済み
3 件のコメント
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - 返信
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - 返信
How do you put the back back on?
Steven Enns - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 34
過去 30 日: 139
今までの合計 29,159
