メインコンテンツにスキップ
Ninja Professional Blender BL660 LED Lights Replacement
必要な工具と部品
  1. Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: 手順 1、 2の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement, Blender Base: 手順 1、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 2、 2の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement: 手順 2、 2の画像 2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 3、 2の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement: 手順 3、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 4、 2の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement: 手順 4、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 5、 2の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement: 手順 5、 2の画像 2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
  6. Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: 手順 6、 3の画像 1 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: 手順 6、 3の画像 2 Ninja Professional Blender BL660 LED Lights  Replacement, LED Lights: 手順 6、 3の画像 3
    • Using the Phillips #2 screwdriver, remove the four screws (10mm long, 5mm wide) on the circuit board.
  7. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 7、 1の画像 1
    • To give the circuit board further range of motion, remove the pictured zip ties holding the cables.
  8. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 8、 1の画像 1
    • Locate the malfunctioning LED lights on the circuit board.
  9. Ninja Professional Blender BL660 LED Lights  Replacement: 手順 9、 1の画像 1
    • Flip the circuit board to view the soldering connections of the LED lights and replace as needed.
    • For instructions on sodering and desoldering reference iFixit's guide.
終わりに
作成者
4人の作成者と共同で作成されました。
Andre Obot
メンバー登録日: 09/22/17
237 ポイント
2のガイドは作成済み
チーム
コメント 1 件
Buenas tardes.
Muy buenas ilustraciones, pero deben poner los números de partes de los repuestos.
Gracias por la información.
Jose Sosa - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 570
