メインコンテンツにスキップ
Ninja Mega Kitchen System BL770 Power Cord Replacement
必要な工具と部品
  1. Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 手順 1、 2の画像 1 Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 手順 1、 2の画像 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 2、 1の画像 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 3、 3の画像 1 Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 3、 3の画像 2 Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 3、 3の画像 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 4、 1の画像 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 手順 5、 2の画像 1 Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 手順 5、 2の画像 2
    • Check that the two red wires shown in the photos are properly soldered to the circuit board.
    • If they seem damaged, resolder the wires to the board.
    • If this doesn't solve the issue, proceed to step 6.
  6. Ninja Mega Kitchen System BL770 Power Cord Replacement: 手順 6、 1の画像 1
    • If the 2 wires in the previous step are connected, it's time to check the 2nd area.
    • Remove the plastic covers and check that the wires are soldered correctly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tommee Walker
メンバー登録日: 08/22/17
823 ポイント
6のガイドは作成済み
チーム
Arkansas State University, Team S1-G4, Chamberlain Fall 2017 Arkansas State University, Team S1-G4, Chamberlain Fall 2017人のメンバー
ARSU-CHAMBERLAIN-F17S1G4
2 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 21
今までの合計 959
