メインコンテンツにスキップ
Nikon D90 Rear LCD Glass Replacement
必要な工具と部品
  1. Nikon D90 Rear LCD Glass Replacement, Rear Case: 手順 1、 2の画像 1 Nikon D90 Rear LCD Glass Replacement, Rear Case: 手順 1、 2の画像 2
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 Rear LCD Glass Replacement: 手順 2、 1の画像 1
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 Rear LCD Glass Replacement: 手順 3、 1の画像 1
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 Rear LCD Glass Replacement: 手順 4、 1の画像 1
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 Rear LCD Glass Replacement: 手順 5、 1の画像 1
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 Rear LCD Glass Replacement: 手順 6、 3の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 6、 3の画像 2 Nikon D90 Rear LCD Glass Replacement: 手順 6、 3の画像 3
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 Rear LCD Glass Replacement: 手順 7、 2の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 7、 2の画像 2
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 Rear LCD Glass Replacement: 手順 8、 1の画像 1
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 Rear LCD Glass Replacement: 手順 9、 3の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 9、 3の画像 2 Nikon D90 Rear LCD Glass Replacement: 手順 9、 3の画像 3
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 Rear LCD Glass Replacement: 手順 10、 1の画像 1
    • Separate the rear casing from the camera.
  11. Nikon D90 Rear LCD Glass Replacement, LCD: 手順 11、 1の画像 1
    • Peel back the yellow tape covering the cable connector on the back of the casing you removed.
  12. Nikon D90 Rear LCD Glass Replacement: 手順 12、 3の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 12、 3の画像 2 Nikon D90 Rear LCD Glass Replacement: 手順 12、 3の画像 3
    • Using the spudger, rock the connector back and forth to disconnect the cable.
  13. Nikon D90 Rear LCD Glass Replacement: 手順 13、 2の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 13、 2の画像 2
    • Remove the eight Phillips screws securing the brackets to the rear casing.
    • Four 4.2mm screws securing the large metal bracket.
    • Four 3.4mm screws securing the bracket that covers the ribbon cable.
  14. Nikon D90 Rear LCD Glass Replacement: 手順 14、 2の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 14、 2の画像 2
    • Remove the silver metal plate.
  15. Nikon D90 Rear LCD Glass Replacement: 手順 15、 2の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 15、 2の画像 2
    • Fold the ribbon cables up and out of the way.
    • Remove the metal shield covering the LCD.
  16. Nikon D90 Rear LCD Glass Replacement: 手順 16、 2の画像 1 Nikon D90 Rear LCD Glass Replacement: 手順 16、 2の画像 2
    • Lift and remove the LCD from the rear case.
  17. Nikon D90 Rear LCD Glass Replacement, Rear LCD Glass: 手順 17、 2の画像 1 Nikon D90 Rear LCD Glass Replacement, Rear LCD Glass: 手順 17、 2の画像 2
    • Using either the iOpener or a heat gun, heat the rear LCD glass enough to melt the adhesive holding it on.
    • The glass will be hot! Let cool before handling.
  18. Nikon D90 Rear LCD Glass Replacement: 手順 18、 1の画像 1
    • Push the glass out from the back side.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ryan Lutz
メンバー登録日: 09/27/11
3,014 ポイント
3のガイドは作成済み
1件のガイドコメント
I did this but when I put the lcd back on it only displays black
Jeremiah Wessling - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 27
今までの合計 4,510
