メインコンテンツにスキップ
Nikon D7000 Tripod Plate Replacement
必要な工具と部品
  1. Nikon D7000 Tripod Plate Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Tripod Plate Replacement: 手順 2、 1の画像 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Tripod Plate Replacement: 手順 3、 2の画像 1 Nikon D7000 Tripod Plate Replacement: 手順 3、 2の画像 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Tripod Plate Replacement: 手順 4、 1の画像 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Tripod Plate Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Tripod Plate Replacement: 手順 6、 1の画像 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Tripod Plate Replacement: 手順 7、 1の画像 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Tripod Plate Replacement: 手順 8、 1の画像 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Tripod Plate Replacement: 手順 9、 1の画像 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Tripod Plate Replacement: 手順 10、 1の画像 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Tripod Plate Replacement: 手順 11、 1の画像 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Tripod Plate Replacement: 手順 12、 1の画像 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Tripod Plate Replacement: 手順 13、 1の画像 1
    • Carefully lift the back case off.
  14. Nikon D7000 Tripod Plate Replacement: 手順 14、 3の画像 1 Nikon D7000 Tripod Plate Replacement: 手順 14、 3の画像 2 Nikon D7000 Tripod Plate Replacement: 手順 14、 3の画像 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Tripod Plate Replacement: 手順 15、 2の画像 1 Nikon D7000 Tripod Plate Replacement: 手順 15、 2の画像 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Tripod Plate Replacement: 手順 16、 1の画像 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Tripod Plate Replacement: 手順 17、 1の画像 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Tripod Plate Replacement: 手順 18、 1の画像 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Tripod Plate Replacement: 手順 19、 3の画像 1 Nikon D7000 Tripod Plate Replacement: 手順 19、 3の画像 2 Nikon D7000 Tripod Plate Replacement: 手順 19、 3の画像 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Tripod Plate Replacement: 手順 20、 2の画像 1 Nikon D7000 Tripod Plate Replacement: 手順 20、 2の画像 2
  21. Nikon D7000 Tripod Plate Replacement: 手順 21、 1の画像 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Tripod Plate Replacement: 手順 22、 1の画像 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Tripod Plate Replacement: 手順 23、 1の画像 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Tripod Plate Replacement: 手順 24、 1の画像 1
    • Lift the motherboard off.
  25. Nikon D7000 Tripod Plate Replacement, Tripod Plate: 手順 25、 1の画像 1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Tripod Plate Replacement: 手順 26、 1の画像 1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jed Chen
メンバー登録日: 04/01/15
1,796 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 2,341
