メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D7000 Image Sensor Replacement
必要な工具と部品
  1. Nikon D7000 Image Sensor Replacement, Motherboard: 手順 1、 1の画像 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Image Sensor Replacement: 手順 2、 1の画像 1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Image Sensor Replacement: 手順 3、 2の画像 1 Nikon D7000 Image Sensor Replacement: 手順 3、 2の画像 2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Image Sensor Replacement: 手順 4、 1の画像 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Image Sensor Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Image Sensor Replacement: 手順 6、 1の画像 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Image Sensor Replacement: 手順 7、 1の画像 1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Image Sensor Replacement: 手順 8、 1の画像 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Image Sensor Replacement: 手順 9、 1の画像 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Image Sensor Replacement: 手順 10、 1の画像 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Image Sensor Replacement: 手順 11、 1の画像 1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Image Sensor Replacement: 手順 12、 1の画像 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Image Sensor Replacement: 手順 13、 1の画像 1
    • Carefully lift the back case off.
  14. Nikon D7000 Image Sensor Replacement: 手順 14、 3の画像 1 Nikon D7000 Image Sensor Replacement: 手順 14、 3の画像 2 Nikon D7000 Image Sensor Replacement: 手順 14、 3の画像 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Image Sensor Replacement: 手順 15、 2の画像 1 Nikon D7000 Image Sensor Replacement: 手順 15、 2の画像 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Image Sensor Replacement: 手順 16、 1の画像 1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Image Sensor Replacement: 手順 17、 1の画像 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Image Sensor Replacement: 手順 18、 1の画像 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Image Sensor Replacement: 手順 19、 3の画像 1 Nikon D7000 Image Sensor Replacement: 手順 19、 3の画像 2 Nikon D7000 Image Sensor Replacement: 手順 19、 3の画像 3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Image Sensor Replacement: 手順 20、 2の画像 1 Nikon D7000 Image Sensor Replacement: 手順 20、 2の画像 2
  21. Nikon D7000 Image Sensor Replacement: 手順 21、 1の画像 1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Image Sensor Replacement: 手順 22、 1の画像 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Image Sensor Replacement: 手順 23、 1の画像 1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Image Sensor Replacement: 手順 24、 1の画像 1
    • Lift the motherboard off.
  25. Nikon D7000 Image Sensor Replacement, Image Sensor: 手順 25、 2の画像 1 Nikon D7000 Image Sensor Replacement, Image Sensor: 手順 25、 2の画像 2
    • Disconnect black and white speaker cable.
  26. Nikon D7000 Image Sensor Replacement: 手順 26、 1の画像 1
    • Remove three 6 mm J000 screws securing the image sensor.
  27. Nikon D7000 Image Sensor Replacement: 手順 27、 1の画像 1
    • Carefully lift the image sensor plate out of the camera.
終わりに
19 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jed Chen
メンバー登録日: 04/01/15
1,829 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G6
3 メンバー
6のガイドは作成済み
4件のガイドコメント
I really need to do this operation! One question: I’m shopping for a replacement sensor and in the photos it looks like the cables off the sensor assembly are free hanging. In this tutorial there is only the disconnection of the black and white speaker cables. Where do these cables go?
Sean McDonald - 返信
I am grateful for this! Thanks - it worked a treat!
Peter Davies - 返信
Thanks, I have done it with the Nikon d7200, it is different I have made some comments already, similar to the Nikon d7100 you have to unscrew the diopter and has 2 screws under the rubber what you have to remove… The motherboard is totally different
Rudi Zimmerer - 返信
Any suggestions for locating a reputable, OEM part? Tons of choices on eBay with widely varying prices. Hints or clues to ensure I am buying authentic and safe parts are appreciated! Thanks!
George Peters - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 22
過去 30 日: 171
今までの合計 11,680
