はじめに
Is your camera no longer working? Did you recently damage your camera, like by dropping it or getting it wet? Your motherboard may be damaged. This guide will show you how to replace it.
必要な工具と部品
Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
Remove the two 3-mm screws from the other side of the camera.
Finally, remove the three 4-mm screws from the bottom of the camera.
この手順で使用する道具:Tweezers$4.99
Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
Lift the button circuit board by gently popping it out of its connector.
Using a #000 Phillips screwdriver, remove the four 4-mm screws from the metal plate.
Remove the solder using a soldering iron by following the instructions in this guide.
Remove the solder connecting the motherboard to the speaker and mic to completely detach the motherboard.
