メインコンテンツにスキップ
Nikon Coolpix P90 Motherboard Replacement
必要な工具と部品
  1. Nikon Coolpix P90 Motherboard Replacement, Camera Base: 手順 1、 3の画像 1 Nikon Coolpix P90 Motherboard Replacement, Camera Base: 手順 1、 3の画像 2 Nikon Coolpix P90 Motherboard Replacement, Camera Base: 手順 1、 3の画像 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Motherboard Replacement, Motherboard: 手順 2、 3の画像 1 Nikon Coolpix P90 Motherboard Replacement, Motherboard: 手順 2、 3の画像 2 Nikon Coolpix P90 Motherboard Replacement, Motherboard: 手順 2、 3の画像 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • Remove both 4.5 mm screws holding the bottom into place.
    • Remove both 4.5 mm screws holding the side into place.
    • Remove the 4.5 mm screw underneath the A/V flap.
    • Remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Nikon Coolpix P90 Motherboard Replacement: 手順 3、 3の画像 1 Nikon Coolpix P90 Motherboard Replacement: 手順 3、 3の画像 2 Nikon Coolpix P90 Motherboard Replacement: 手順 3、 3の画像 3
    • Carefully lift the back cover from the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  4. Nikon Coolpix P90 Motherboard Replacement: 手順 4、 2の画像 1 Nikon Coolpix P90 Motherboard Replacement: 手順 4、 2の画像 2
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
    • Be careful when releasing the safety latch because it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  5. Nikon Coolpix P90 Motherboard Replacement: 手順 5、 2の画像 1 Nikon Coolpix P90 Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the seven 4.0 mm screws that connect the metal plate to the motherboard.
    • Remove the three 4.0 mm screws that connect the metal hinges to the camera body.
  6. Nikon Coolpix P90 Motherboard Replacement: 手順 6、 1の画像 1
    • Carefully lift the metal backing from the motherboard.
    • Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard.
  7. Nikon Coolpix P90 Motherboard Replacement: 手順 7、 2の画像 1 Nikon Coolpix P90 Motherboard Replacement: 手順 7、 2の画像 2
    • It is now safe to completely remove the metal backing from the camera.
  8. Nikon Coolpix P90 Motherboard Replacement: 手順 8、 1の画像 1
    • Using a Phillips #000 Precision Screwdriver, remove the three 3.0 mm screws from the motherboard.
  9. Nikon Coolpix P90 Motherboard Replacement: 手順 9、 1の画像 1
    • Press your finger on the top of the latches and pull them down and toward you to open the safety latches and free the five data transfer ribbons.
    • Be careful when releasing the safety latches because they are fragile and may break easily.
    • Slide the five ribbons out from their sockets.
  10. Nikon Coolpix P90 Motherboard Replacement: 手順 10、 2の画像 1 Nikon Coolpix P90 Motherboard Replacement: 手順 10、 2の画像 2
    • Desolder the wires to fully disconnect the motherboard from the camera.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Elizabeth Kamine
メンバー登録日: 01/22/15
655 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-14, Maness Winter 2015 Cal Poly, Team 20-14, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S20G14
4 メンバー
7のガイドは作成済み
2 件のコメント
By the way on step 10, you show the soldering iron right beside the "RD" red wire near top middle which should be discharged before you get the shitfuckpiss scared out of you and drop your soldering iron in your lap. There's gotta be several thousand volts on that connection, I discharged it with alligator clips to ground after going through my fingers a couple times (before finding which one it was) about 6 times and it was extremely bright and loud. PS. My arm is numb at least to my elbows on this one! ...and I might need a new pair of pants, from either the $@$*, !#^&, or soldering iron. :(
Xexorian - 返信
Can a torn ribbon be fixed??
Edgar Ramirez - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 20
今までの合計 1,474
