メインコンテンツにスキップ
Nikon Coolpix B700 Lens Assembly Replacement
必要な工具と部品
  1. Nikon Coolpix B700 Lens Assembly Replacement, Back Frame Assembly: 手順 1、 1の画像 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Lens Assembly Replacement: 手順 2、 1の画像 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Lens Assembly Replacement: 手順 3、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 3、 2の画像 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Lens Assembly Replacement: 手順 4、 1の画像 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Lens Assembly Replacement: 手順 5、 3の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 5、 3の画像 2 Nikon Coolpix B700 Lens Assembly Replacement: 手順 5、 3の画像 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
    Here the HDMI cover also comes off by itself.
    Tim T - 返信
  6. Nikon Coolpix B700 Lens Assembly Replacement: 手順 6、 1の画像 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Lens Assembly Replacement: 手順 7、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 7、 2の画像 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
    How to check the rear part my b700 will turn ON when i disconected the 2 ribbons
    josesalgado74 - 返信
  8. Nikon Coolpix B700 Lens Assembly Replacement, Internal Bracket: 手順 8、 1の画像 1
    • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
    • Remove the single 6mm screw.
    The screw to unscrew on the bottom left seems to not exist or is covered by a foam which is as large as the grey area around in the picture.
    Tim T - 返信
    Also from this step to the next the golden cover got removed it seems.
    Tim T - 返信
    I removed the left screw on the golden cover as well.
    Tim T - 返信
  9. Nikon Coolpix B700 Lens Assembly Replacement: 手順 9、 1の画像 1
    • Insert the pry tool under the latch and gently lift up to remove the ribbon.
  10. Nikon Coolpix B700 Lens Assembly Replacement: 手順 10、 1の画像 1
    • Move the ribbon out of the way to reveal the hidden screw.
    I think the revealed 4mm screw has to be removed.
    Tim T - 返信
  11. Nikon Coolpix B700 Lens Assembly Replacement: 手順 11、 1の画像 1
    • Lift the button assembly gently to give access to remove the 4mm screw.
  12. Nikon Coolpix B700 Lens Assembly Replacement: 手順 12、 1の画像 1
    • On the top of the camera, remove the 6mm screw.
  13. Nikon Coolpix B700 Lens Assembly Replacement: 手順 13、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 13、 2の画像 2
    • With the spudger tool gently pry off the white tap holding in the bracket.
    • Use the same tool to remove the glued-on ribbon.
  14. Nikon Coolpix B700 Lens Assembly Replacement: 手順 14、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 14、 2の画像 2
    • Gently lift up the button assembly to slide the bracket out.
  15. Nikon Coolpix B700 Lens Assembly Replacement: 手順 15、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 15、 2の画像 2
    • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
    • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
  16. Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: 手順 16、 2の画像 1 Nikon Coolpix B700 Lens Assembly Replacement, Lens Assembly: 手順 16、 2の画像 2
    • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
    the screw driver I got drom the starter toolkit is 0.5mm too short to remove the last two screws nicely. But it works.
    Tim T - 返信
  17. Nikon Coolpix B700 Lens Assembly Replacement: 手順 17、 1の画像 1
    • Remove the tripod mount from it's slot.
  18. Nikon Coolpix B700 Lens Assembly Replacement: 手順 18、 3の画像 1 Nikon Coolpix B700 Lens Assembly Replacement: 手順 18、 3の画像 2 Nikon Coolpix B700 Lens Assembly Replacement: 手順 18、 3の画像 3
    • Now you just have to slide the lens assembly out of the housing.
    my nikon b700 camera lense is deffective and I want remove and inspect the lense, I want find what is wrong inside of the lense, I would lije fix it your guidance help me a lot opening and checking wrong contacts in my camera, but I found deffective my lense you are good teacher
    federico chavez - 返信
終わりに
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Carlos Salgado
メンバー登録日: 02/27/19
1,456 ポイント
7のガイドは作成済み
チーム
Purdue University Northwest, Team S4-G5, Hingst Spring 2019 Purdue University Northwest, Team S4-G5, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S4G5
4 メンバー
14のガイドは作成済み
2 Guide Comments
how to reset an objective error on B700 ? the lens is stopped in the middle of a hike
Per Benny Paulsen - 返信
how to reset an objective error? the lens is stopped in the middle of a hike
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 37
今までの合計 3,098
