はじめに
Use this guide to replace a malfunctioning battery. This replacement guide requires a Soldering Iron, it would be very helpful to heat the iron up before starting this guide, this process can take 3-4 minutes. You should refer to iFixit's soldering guide to help with the desoldering/soldering process.
必要な工具と部品
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
4 の人々がこのガイドを完成させました。
3 件のコメント
Excellent guide, easy to follow, very concise, very good photographs. Thank you
Donde puedo encontrar una batería
Lauraelena - 返信
