メインコンテンツにスキップ
Netgear ProSAFE GS105 Gigabit Switch Disassembly
必要な工具と部品
  1. Netgear ProSAFE GS105 Gigabit Switch Disassembly, Remove screws from rear of device.: 手順 1、 1の画像 1
    • Remove the two 4.04 mm Phillips Head screws with a PH1 bit or Phillips #1 Screwdriver and set screws aside.
  2. Netgear ProSAFE GS105 Gigabit Switch Disassembly, Remove top cover from device.: 手順 2、 2の画像 1 Netgear ProSAFE GS105 Gigabit Switch Disassembly, Remove top cover from device.: 手順 2、 2の画像 2
    • Use gentle pressure to pull back the top and rear panel of the switch away from the body and set side.
  3. Netgear ProSAFE GS105 Gigabit Switch Disassembly, Remove screws holding the board into the case.: 手順 3、 1の画像 1
    • Use your PH2 bit or a Phillips #2 Screwdriver to remove the 6.94mm Phillips Head screws that hold the board into the bottom of the case.
    • CAUTION: The screws have two washers on each screw, make use you keep these with the screws.
  4. Netgear ProSAFE GS105 Gigabit Switch Disassembly, Remove board from the case.: 手順 4、 1の画像 1
    • Use light pressure to lift the board from the screw standoffs and gently pull backwards to remove the board from the case.
    • When reassembling the device make sure you correctly line up the RJ45 ports with the front of the case and the board is properly sitting on the screw standoffs before re-inserting the screws.
  5. Netgear ProSAFE GS105 Gigabit Switch Disassembly, Device is disassembled.: 手順 5、 1の画像 1
    • The board has now been removed from the casing and is ready for maintenance or repair.
    • In order to the put the device back together follow the steps outlined in reverse.
終わりに
You are now finished!
作成者
3人の作成者と共同で作成されました。
Matt Sibley
メンバー登録日: 06/23/18
308 ポイント
1ガイドが承認済み
コメント 1 件
is there some associated repair guide (like for one that won't power up), or only this Disassembly Guide? (if only the latter, then why bother?). While not worth repairing for any cost savings (they can be had for $15 second hand), they would be good devices for practicing repair skills like diagnosing and replacing board components, with little risk.
DavidM - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 69
今までの合計 2,719
