メインコンテンツにスキップ
Nest Cam IQ Motherboard Replacement
必要な工具と部品
  1. Nest Cam IQ Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Motherboard Replacement: 手順 2、 1の画像 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Motherboard Replacement: 手順 3、 1の画像 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Motherboard Replacement: 手順 4、 2の画像 1 Nest Cam IQ Motherboard Replacement: 手順 4、 2の画像 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Motherboard Replacement: 手順 5、 2の画像 1 Nest Cam IQ Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Motherboard Replacement: 手順 6、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 6、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 6、 3の画像 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Motherboard Replacement: 手順 8、 2の画像 1 Nest Cam IQ Motherboard Replacement: 手順 8、 2の画像 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Motherboard Replacement: 手順 9、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 9、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 9、 3の画像 3
    • Remove the three 19 mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Motherboard Replacement: 手順 10、 2の画像 1 Nest Cam IQ Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the one 4 mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Motherboard Replacement: 手順 11、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 11、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 11、 3の画像 3
    • Remove the four 11 mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Motherboard Replacement: 手順 12、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 12、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 12、 3の画像 3
    • Carefully remove the mounting stand.
    • Remove the three 9 mm TR6 Torx connecting the motherboard and speaker to the body.
    • Pull the motherboard and speaker from the body.
  13. Nest Cam IQ Motherboard Replacement: 手順 13、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 13、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 13、 3の画像 3
    • Remove the one 8 mm TR6 Torx screws securing the speaker to the motherboard.
    • Remove the two 4 mm TR6 Torx screws securing the speaker to the motherboard.
    • Carefully pull away the speaker.
    • As you pull away the speaker, be careful not to damage the cable connecting the speaker to the motherboard.
    • Carefully disconnect the cable connecting the speaker to the motherboard.
  14. Nest Cam IQ Motherboard Replacement: 手順 14、 3の画像 1 Nest Cam IQ Motherboard Replacement: 手順 14、 3の画像 2 Nest Cam IQ Motherboard Replacement: 手順 14、 3の画像 3
    • Remove the four 4 mm TR6 Torx screws securing the motherboard.
    • Remove the two 5 mm 3.5 low-head socket cap screws securing the motherboard.
    • Remove the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Jas Ownby
メンバー登録日: 09/08/23
800 ポイント
4のガイドは作成済み
チーム
University of New Orleans, Team 5-5, McDonald Fall 2023 University of New Orleans, Team 5-5, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S5G5
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 112
