メインコンテンツにスキップ
Nest Cam IQ Camera Replacement
必要な工具と部品
  1. Nest Cam IQ Camera Replacement, Camera: 手順 1、 1の画像 1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Camera Replacement: 手順 2、 1の画像 1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Camera Replacement: 手順 3、 1の画像 1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Camera Replacement: 手順 4、 2の画像 1 Nest Cam IQ Camera Replacement: 手順 4、 2の画像 2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Camera Replacement: 手順 5、 2の画像 1 Nest Cam IQ Camera Replacement: 手順 5、 2の画像 2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Camera Replacement: 手順 6、 3の画像 1 Nest Cam IQ Camera Replacement: 手順 6、 3の画像 2 Nest Cam IQ Camera Replacement: 手順 6、 3の画像 3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Camera Replacement: 手順 7、 1の画像 1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Camera Replacement: 手順 8、 2の画像 1 Nest Cam IQ Camera Replacement: 手順 8、 2の画像 2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jas Ownby
メンバー登録日: 09/08/23
800 ポイント
4のガイドは作成済み
チーム
University of New Orleans, Team 5-5, McDonald Fall 2023 University of New Orleans, Team 5-5, McDonald Fall 2023人のメンバー
UNO-MCDONALD-F23S5G5
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 163
