メインコンテンツにスキップ
Munchkin Mozart Magic Cube Light Replacement
必要な工具と部品
  1. Munchkin Mozart Magic Cube Light Replacement, Face plate: 手順 1、 2の画像 1 Munchkin Mozart Magic Cube Light Replacement, Face plate: 手順 1、 2の画像 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Light Replacement: 手順 2、 1の画像 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Light Replacement: 手順 3、 1の画像 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Light Replacement: 手順 4、 1の画像 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Light Replacement: 手順 5、 1の画像 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Light Replacement: 手順 6、 1の画像 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Light Replacement: 手順 7、 1の画像 1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Light Replacement, Frame Removal: 手順 8、 1の画像 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube Light Replacement, Light: 手順 9、 1の画像 1
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
    • Use the Jimmy to remove the glue connecting the motherboard to the white frame.
  10. Munchkin Mozart Magic Cube Light Replacement: 手順 10、 1の画像 1
    • Slide the motherboard out of the frame.
  11. Munchkin Mozart Magic Cube Light Replacement: 手順 11、 1の画像 1
  12. Munchkin Mozart Magic Cube Light Replacement: 手順 12、 1の画像 1
    • Take the new LED and solder the two legs back to the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nikolas Soulandros
メンバー登録日: 08/27/15
291 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S1G4
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 486
