メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola V710 LCD screen replacement
必要な工具と部品
  1. Motorola V710 LCD screen replacement, Screen: 手順 1、 3の画像 1 Motorola V710 LCD screen replacement, Screen: 手順 1、 3の画像 2 Motorola V710 LCD screen replacement, Screen: 手順 1、 3の画像 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola V710 LCD screen replacement: 手順 2、 2の画像 1 Motorola V710 LCD screen replacement: 手順 2、 2の画像 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola V710 LCD screen replacement: 手順 3、 2の画像 1 Motorola V710 LCD screen replacement: 手順 3、 2の画像 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola V710 LCD screen replacement: 手順 4、 2の画像 1 Motorola V710 LCD screen replacement: 手順 4、 2の画像 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola V710 LCD screen replacement: 手順 5、 2の画像 1 Motorola V710 LCD screen replacement: 手順 5、 2の画像 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola V710 LCD screen replacement: 手順 6、 2の画像 1 Motorola V710 LCD screen replacement: 手順 6、 2の画像 2
    • Use the spudger to remove the screen.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Michael Onnen
メンバー登録日: 01/26/10
11 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G49
5 メンバー
32のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 20
今までの合計 2,394
