はじめに
Follow this guide to remove or replace the loudspeaker in a Motorola Moto E6 Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
必要な工具と部品
Use an opening tool or your fingernail to pry the back cover away from the frame using the notch at the bottom right corner.
Use an opening tool or your fingernail to release the clips on the right edge by sliding up and around the top right corner.
Continue to slide the opening tool or your fingernail across the top edge to release the clips securing the back cover to the frame.
Continue to slide the opening tool or your fingernail down the left edge to release the clips.
Use a spudger or your fingernail to pry the battery up using the notch near the bottom right corner.
Remove the battery.
Use a Torx T3 driver to remove the three 3.6 mm-long screws securing the loudspeaker to the frame.
Use a Phillips screwdriver to remove the four 3.1 mm-long screws.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto E6 Plus Answers community for help.
