メインコンテンツにスキップ
Motorola Moto E4 Plus Rear-Facing Camera Replacement
必要な工具と部品
  1. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the back cover: 手順 1、 3の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the back cover: 手順 1、 3の画像 2 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the back cover: 手順 1、 3の画像 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear-Facing Camera Replacement: 手順 2、 2の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement: 手順 2、 2の画像 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the midframe screws: 手順 3、 1の画像 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Release the midframe clips: 手順 4、 2の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Release the midframe clips: 手順 4、 2の画像 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the midframe: 手順 5、 2の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the midframe: 手順 5、 2の画像 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Disconnect the battery: 手順 6、 2の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Disconnect the battery: 手順 6、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Disconnect the camera: 手順 7、 2の画像 1 Motorola Moto E4 Plus Rear-Facing Camera Replacement, Disconnect the camera: 手順 7、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the rear-facing camera module connector from its motherboard socket.
  8. Motorola Moto E4 Plus Rear-Facing Camera Replacement, Remove the camera: 手順 8、 1の画像 1
    • Remove the rear-facing camera.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
作成者
1人の作成者と共同作成されました。
Arthur Shi
メンバー登録日: 01/03/18
258,916 ポイント
531のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,077のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 297
