はじめに
Follow this guide to remove and replace the daughterboard on the Moto E4 Plus. The daughterboard houses the charging port, a downward facing microphone, and the vibration motor.
ツール
パーツ
パーツは指定されていません。
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
Twist the spudger to release the plastic clip.
Repeat the process for the clip near the top right corner of the phone.
Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
Remove the plastic midframe.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
Remove the two 3.2 mm long T3 screws securing the daughterboard.
Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
Grasp the daughterboard by the edges and lift it out of its recess.
Remove the daughterboard. The vibration motor will be attached to it.
ある他の人がこのガイドを完成しました。
