メインコンテンツにスキップ
Motorola Droid Turbo Motherboard Replacement
必要な工具と部品
  1. Motorola Droid Turbo Motherboard Replacement, Rear Case: 手順 1、 1の画像 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Motherboard Replacement: 手順 2、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Motherboard Replacement, Midframe: 手順 3、 1の画像 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the midframe.
  6. Motorola Droid Turbo Motherboard Replacement, Battery: 手順 6、 2の画像 1 Motorola Droid Turbo Motherboard Replacement, Battery: 手順 6、 2の画像 2
    • Use the point of a spudger to pop up the battery connector.
  7. Motorola Droid Turbo Motherboard Replacement: 手順 7、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 7、 2の画像 2
    • Fold the wireless charging coil away from the battery.
  8. Motorola Droid Turbo Motherboard Replacement: 手順 8、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 8、 2の画像 2
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
  9. Motorola Droid Turbo Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
  10. Motorola Droid Turbo Motherboard Replacement: 手順 10、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the lower antenna board.
  11. Motorola Droid Turbo Motherboard Replacement: 手順 11、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the SIM card holder/volume button rocker.
  12. Motorola Droid Turbo Motherboard Replacement: 手順 12、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 12、 2の画像 2
    • Carefully lift up the motherboard to expose the display connector.
  13. Motorola Droid Turbo Motherboard Replacement: 手順 13、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 13、 2の画像 2
    • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
    • Pull the display ribbon cable free of the connector.
    • At this point, the motherboard has been removed from the phone. The following steps will detail removing the wireless charging coil, as well as both cameras so that they can be transferred to the replacement motherboard.
  14. Motorola Droid Turbo Motherboard Replacement: 手順 14、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 14、 2の画像 2
    • Use the flat end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  15. Motorola Droid Turbo Motherboard Replacement: 手順 15、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 15、 2の画像 2
    • Use the flat end of a spudger to flip up the black retaining flap on the front-facing camera ZIF connector.
  16. Motorola Droid Turbo Motherboard Replacement: 手順 16、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 16、 2の画像 2
    • Remove the front-facing camera.
  17. Motorola Droid Turbo Motherboard Replacement: 手順 17、 2の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 17、 2の画像 2
    • Use the flat end of a spudger to flip up the tan retaining flap on the rear-facing camera ZIF connector.
  18. Motorola Droid Turbo Motherboard Replacement: 手順 18、 3の画像 1 Motorola Droid Turbo Motherboard Replacement: 手順 18、 3の画像 2 Motorola Droid Turbo Motherboard Replacement: 手順 18、 3の画像 3
    • Remove the rear-facing camera.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Luis Arangu
メンバー登録日: 01/20/16
1,142 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 15-5, Remmell Spring 2016 USF Tampa, Team 15-5, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S15G5
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 7,412
