メインコンテンツにスキップ
Motorola Droid Turbo Midframe Replacement
必要な工具と部品
  1. Motorola Droid Turbo Midframe Replacement, Rear Case: 手順 1、 1の画像 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    This di not work; I had to use a blow dryer.
    Caroline Downie - 返信
  2. Motorola Droid Turbo Midframe Replacement: 手順 2、 2の画像 1 Motorola Droid Turbo Midframe Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
    Ryan Helinski - 返信
  3. Motorola Droid Turbo Midframe Replacement, Midframe: 手順 3、 1の画像 1
    • Remove the midframe bezel.
    The next immediate step should be to remove the cable for the battery from the motherboard, lower left corner. That will keep you from accidentally turning the phone on while working with it.
    decker5 - 返信
  4. Motorola Droid Turbo Midframe Replacement: 手順 4、 1の画像 1
    • Remove the four Torx T5 screws securing the midframe plate.
    Step 4, there are also 2 T shaped tabs on the sides locking the mid frame plate. Above them you can see an angled hole where you can insert a paper clip to push them out and up to unlock them.
    Mike Mangiaruca - 返信
    The WiFi on the Turbo I’m working on has stopped working. The phone was reset to factory to see if this would fix it after all other try-this-first methods to fix had failed. I opened it to check there and find nothing apparently wrong.. No bent connectors or dirty pins. Any suggestions? I started to clean this section with alcohol but decided I’d better ask first. Any suggestions?
    Rongwey - 返信
  5. Motorola Droid Turbo Midframe Replacement: 手順 5、 1の画像 1
    • Remove the midframe.
    There's two clips to the left and the right of the midframe. Use a SIM tool and insert them into the holes above the clips, and push the clips out from the inside. Once both have been pushed the midframe is released.
    rkarnes1988 - 返信
    Many ANY thanks for that additional tip. Rather important!
    Nate Baxley -
終わりに
ある他の人がこのガイドを完成しました。
Geoff Wacker
メンバー登録日: 09/30/13
91,137 ポイント
89のガイドは作成済み
1 Guide Comment
Which circuits depend of the midframe?
gabriel.mourasant - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 17
今までの合計 1,208
