メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola DROID MAXX Full Screen Replacement
必要な工具と部品
    1. Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 手順 1、 3の画像 1 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 手順 1、 3の画像 2 Motorola DROID MAXX Full Screen  Replacement, Screen Assembly Replacement: 手順 1、 3の画像 3
      • Find the volume buttons located on the side of the Droid Maxx.
      • Take the plastic opening tool and insert it into the gap between the volume buttons and the case.
      • Using the flat tip of the plastic opening tool, press firmly against the case until you hear a “snap” sound.
      • Remove the buttons carefully. Do not bend or force the part since it also serves as a tray for placing a SIM Card.
      FixBotに聞いてみる
      コメントを追加
    2. Motorola DROID MAXX Full Screen  Replacement: 手順 2、 3の画像 1 Motorola DROID MAXX Full Screen  Replacement: 手順 2、 3の画像 2 Motorola DROID MAXX Full Screen  Replacement: 手順 2、 3の画像 3
      • Using the flat tip of the plastic opening tool, press firmly against the case until you hear an audible click.
      • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
      FixBotに聞いてみる
      コメントを追加
    3. Motorola DROID MAXX Full Screen  Replacement: 手順 3、 3の画像 1 Motorola DROID MAXX Full Screen  Replacement: 手順 3、 3の画像 2 Motorola DROID MAXX Full Screen  Replacement: 手順 3、 3の画像 3
      • Using the Torx T5 Screwdriver, carefully remove all of the screws in the motherboard.
      • There are 8 black screws: 4 at the top and 4 at the bottom of the motherboard.
      • There are 2 silver screws on the side: 1 at the bottom and 1 in the middle.
      • Use either a T3 (Ultra) or T4 (MAXX) to remove the single screw securing the camera housing.
      • Using the plastic opening tool, gently lift the two tabs in the upper plastic cover that surrounds the camera to release the cover.
      FixBotに聞いてみる
      コメントを追加
    4. Motorola DROID MAXX Full Screen  Replacement: 手順 4、 3の画像 1 Motorola DROID MAXX Full Screen  Replacement: 手順 4、 3の画像 2 Motorola DROID MAXX Full Screen  Replacement: 手順 4、 3の画像 3
      • Carefully disconnect the ribbon cable from the motherboard and front screen.
      • Place the ribbon cable under the orange tape during reassembly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Jordan
メンバー登録日: 03/01/17
227 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G4, Harley Spring 2017 IUPUI, Team S2-G4, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S2G4
4 メンバー
12のガイドは作成済み
2件のガイドコメント
Where can I purchase the screen replacement for the droid maxx
Zachary lawson - 返信 共有
That 3mm screw is a ##&&%. BE VERY CAREFUL WITH IT! I haven’t figured out how to best loosen it yet; maybe small turn bursts so you don’t break the tines?
Ron Herren - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 6,969
