はじめに
To remove the speaker you will need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver and a spudger.
必要な工具と部品
この手順で使用する道具:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
この手順で使用する道具:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
この手順で使用する道具:Spudger$3.99
Insert a spudger between the black plastic and the motherboard.
Lift upwards with the spudger to dislodge the board.
The speaker can be found on the bottom of the inside of the back case and is held in by glue.
Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
2 の人々がこのガイドを完成させました。
