メインコンテンツにスキップ
Motorola Atrix 4G Bottom Speaker Replacement
必要な工具と部品
  1. Motorola Atrix 4G Bottom Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Pry the back cover off the back of the phone.
  2. Motorola Atrix 4G Bottom Speaker Replacement: 手順 2、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    • Insert a spudger into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Bottom Speaker Replacement, Antenna: 手順 3、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement, Antenna: 手順 3、 2の画像 2
    この手順で使用する道具:
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Use gentle force while unscrewing to avoid stripping the screws.
  4. Motorola Atrix 4G Bottom Speaker Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
  5. Motorola Atrix 4G Bottom Speaker Replacement: 手順 5、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Gently lift the tabs located at the top of the phone using an opening tool.
    • Gently lift the tab located at the bottom of the phone with the same tool.
    • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
  6. Motorola Atrix 4G Bottom Speaker Replacement: 手順 6、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the front and back of the case.
    • Slide the tool down the side of the phone.
    • Repeat the same process for the other side.
    • There should be a noticeable gap between the front and back cases. If not, repeat this step.
  7. Motorola Atrix 4G Bottom Speaker Replacement: 手順 7、 1の画像 1
    • Carefully lift the back case off the phone.
    • Do not completely separate the back case from the phone. The antenna is connected to both cases.
  8. Motorola Atrix 4G Bottom Speaker Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
    • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
  9. Motorola Atrix 4G Bottom Speaker Replacement: 手順 9、 1の画像 1
    • Ease the antenna from out of its guide along the side of the phone
    • Remove the back case and the antenna from the phone.
    • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
  10. Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: 手順 10、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: 手順 10、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    • Insert a spudger between the black plastic and the motherboard.
    • Lift upwards with the spudger to dislodge the board.
    • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
  11. Motorola Atrix 4G Bottom Speaker Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    Spudger
    $3.99
    • Disconnect the press connectors using a spudger.
    • If you are unfamiliar with using connectors, consult this guide.
  12. Motorola Atrix 4G Bottom Speaker Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    Spudger
    $3.99
    • Lift the white latch on the ZIF connector using a spudger.
    • Gently pull the black ribbon down and away from the latch.
  13. Motorola Atrix 4G Bottom Speaker Replacement: 手順 13、 1の画像 1
    • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
  14. Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: 手順 14、 2の画像 1 Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: 手順 14、 2の画像 2
    • The speaker can be found on the bottom of the inside of the back case and is held in by glue.
    • Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jake
メンバー登録日: 04/19/12
515 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G42
6 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 14
今までの合計 3,530
