メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
In the event that the flash is not working properly due to internal issues and not settings, it is possible to replace the capacitor to restore function to the flash.
パーツ
パーツは指定されていません。
  1. Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  3. Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  4. Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges. On the front side of the camera, locate the flash battery holder.
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
終わりに
ある他の人がこのガイドを完成しました。
Qqq
メンバー登録日: 2013年03月11日
19 ポイント
1ガイドが承認済み
コメント1件
Its a cap not a battery :D
Eigirdas Gedgaudas - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 679
