危険
潜在的な危険
この手順に正しく従わない場合は損傷が生じる可能性があります。ご注意のうえ使用し、すべての警告に従ってください。
危険
はじめに
In the event that the flash is not working properly due to internal issues and not settings, it is possible to replace the battery to restore function to the flash.
パーツ
パーツは必要ありません。
  1. Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  4. On the front side of the camera, locate the flash battery holder. Lift the housing and remove the battery.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
まとめ
ある他の人がこのガイドを完成しました。
Qqq
メンバー登録日: 2013年03月11日
19 ポイント
1ガイドが承認済み
コメント1件
Its a cap not a battery :D
Eigirdas Gedgaudas - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 605
