メインコンテンツにスキップ
Microsoft Surface Pro Battery Replacement
必要な工具と部品
  1. Microsoft Surface Pro Battery Replacement, Heat edges of display: 手順 1、 1の画像 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
  2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: 手順 2、 3の画像 1 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: 手順 2、 3の画像 2 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: 手順 2、 3の画像 3
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
    • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: 手順 3、 3の画像 1 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: 手順 3、 3の画像 2 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: 手順 3、 3の画像 3
    • Starting from the top edge, lift the display slightly.
    • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display:
    • Disconnect the three display cables.
    • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
  4. Microsoft Surface Pro Battery Replacement, Removal: 手順 4、 1の画像 1
    • Remove the display.
  5. Microsoft Surface Pro Battery Replacement, Battery: 手順 5、 2の画像 1 Microsoft Surface Pro Battery Replacement, Battery: 手順 5、 2の画像 2
    • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
  6. Microsoft Surface Pro Battery Replacement: 手順 6、 1の画像 1
    • Lift the screen bezel from the Surface Pro.
  7. Microsoft Surface Pro Battery Replacement: 手順 7、 2の画像 1 Microsoft Surface Pro Battery Replacement: 手順 7、 2の画像 2
    • Remove the 6 T5 screws from the panels on each side of the frame.
    • Remove 23 T2 screws from the panels.
  8. Microsoft Surface Pro Battery Replacement: 手順 8、 1の画像 1
    • Lift both metal panels from the frame.
  9. Microsoft Surface Pro Battery Replacement: 手順 9、 2の画像 1 Microsoft Surface Pro Battery Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
  10. Microsoft Surface Pro Battery Replacement: 手順 10、 2の画像 1 Microsoft Surface Pro Battery Replacement: 手順 10、 2の画像 2
    • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
  11. Microsoft Surface Pro Battery Replacement: 手順 11、 1の画像 1
    • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
  12. Microsoft Surface Pro Battery Replacement: 手順 12、 2の画像 1 Microsoft Surface Pro Battery Replacement: 手順 12、 2の画像 2
    • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
終わりに
39 の人々がこのガイドを完成させました。
作成者
15人の作成者と共同で作成されました。
Jonathan Choi
メンバー登録日: 10/09/13
1,065 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013人のメンバー
CPSU-REGAN-F13S8G20
4 メンバー
16のガイドは作成済み
24 件のコメント
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - 返信
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons -
im also looking for a surface pro replacement battery.
Lekan Adesanya - 返信
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt -
Did you have success installing the Newegg battery?
asmac - 返信
コメントを追加
統計データ:
過去 24時間: 40
過去 7 日: 286
過去 30 日: 1,396
今までの合計 249,942
