メインコンテンツにスキップ
Microsoft Surface Pro 7 Screen Adhesive Replacement
必要な工具と部品
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 手順 1、 3の画像 1 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 手順 1、 3の画像 2 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: 手順 1、 3の画像 3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 手順 2、 2の画像 1 Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: 手順 2、 2の画像 2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: 手順 3、 1の画像 1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Sam Omiotek
メンバー登録日: 02/25/19
72,896 ポイント
288のガイドは作成済み
2 件のコメント
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - 返信
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 43
過去 30 日: 166
今までの合計 4,212
