はじめに
Use this guide to replace the fans in your Microsoft Surface Pro 2.
This guide is for a Microsoft Surface Pro 2 (Model Number: 6CX-00001RB ) if it is overheating or making loud grinding noises. If you are having these issues with your device the Microsoft Surface Pro 2 Fans (P/N: KDB04105HB CK91 DF43) may need to be replaced. These issues may occur through extended use of the device or other possible damage sources like dropping the device. Replacing this fans prevent further damage from the overheating of the device or from the grinding of the fans.
This guide will show you in detail how to replace these fans in a safe manner. However, this guide is above average in difficulty because you will need have proficiency with both a heat gun and an opening tool to remove the screen of the device. After replacing the fans, follow the guide in reverse order to reassemble the device.
必要な工具と部品
Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
Remove the 22 screws on the bezel.
Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
On the underside of the motherboard locate the heat shield which is located between the two fans near the top of the motherboard.
Remove the heat shield using an opening pick by lifting along the edges.
Remove all four Torx T5 screws located in each corner of the heat sink mounting frame.
Carefully lift off the heat sinks from the motherboard.
3 の人々がこのガイドを完成させました。
