メインコンテンツにスキップ
Microsoft Band Screen Frame Replacement
必要な工具と部品
  1. Microsoft Band Screen Frame Replacement, Screen Frame: 手順 1、 1の画像 1
    • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
    • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
    • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
    • When using the iOpener, make sure to wrap it partially around the sides.
  2. Microsoft Band Screen Frame Replacement: 手順 2、 1の画像 1
    • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
    • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
  3. Microsoft Band Screen Frame Replacement: 手順 3、 2の画像 1 Microsoft Band Screen Frame Replacement: 手順 3、 2の画像 2
    • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
    • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
    • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
    • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
終わりに
作成者
4人の作成者と共同で作成されました。
Alan Robison
メンバー登録日: 02/01/15
194 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G34
4 メンバー
6のガイドは作成済み
2件のガイドコメント
Where do you purchase the new screen frame? I can't seem to locate where to purchase the replacement parts.
TImmyk - 返信
Where can I get band 2 screen cover or just parts?
Alex - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 20
今までの合計 1,173
