メインコンテンツにスキップ
Microsoft Band Motherboard Replacement
必要な工具と部品
  1. Microsoft Band Motherboard Replacement, Screen Frame: 手順 1、 1の画像 1
    • To avoid burning your hands, make sure to hold only the thin edges of the iOpener.
    • Heat the iOpener. Instructions on how to do this can be found here: iOpener Instructions
    • Firmly press the frame of the band against the iOpener, and hold it in place for about 90 seconds.
    • When using the iOpener, make sure to wrap it partially around the sides.
  2. Microsoft Band Motherboard Replacement: 手順 2、 1の画像 1
    • Using a spudger, lightly press upwards against one corner of the frame, then the other along the corner of the short edge.
    • Alternating between the same two corners, continue pressing until there's about a 1-2 mm gap between that end of the frame and the body.
  3. Microsoft Band Motherboard Replacement: 手順 3、 2の画像 1 Microsoft Band Motherboard Replacement: 手順 3、 2の画像 2
    • Do not pull the frame away too quickly. The screen may be stuck to the frame, and pulling on it could cause damage. If the screen is still attached, lightly push on the screen with a finger and it should pop out.
    • Insert the spudger into the gap under the frame, and lightly slide it about 3/4 of the way down one of the long edges, then repeat with the other.
    • If the frame doesn't simply pop off, try sliding the spudger the rest of the way down the long edges, and lightly lift the frame with your fingers.
    • When re-assembling, make sure the frame's microphone hole is on the same side as the sensor board underneath.
  4. Microsoft Band Motherboard Replacement, LCD Screen: 手順 4、 1の画像 1
    • Do not rip the yellow ribbon cable from the motherboard.
    • Gently lift the LCD screen from the components using your fingertips.
  5. Microsoft Band Motherboard Replacement: 手順 5、 1の画像 1
    • Lightly pry up the black connector from the motherboard using a spudger.
    • Pull the entire LCD screen gently upward to detach the yellow ribbon cable.
  6. Microsoft Band Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Using the spudger or the plastic opening tool, gently lift the sensor ribbon.
  7. Microsoft Band Motherboard Replacement: 手順 7、 2の画像 1 Microsoft Band Motherboard Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the spudger or the tweezers, gently detach the golden connector from the motherboard.
  8. Microsoft Band Motherboard Replacement: 手順 8、 1の画像 1
    • Using the T3 Torx screwdriver, remove the two 2 mm T3 screws.
    • When you are reassembling, lift the sensor ribbon so that it's not in the way.
  9. Microsoft Band Motherboard Replacement: 手順 9、 1の画像 1
    • Be gentle. Make sure not to rip apart the cord underneath that connects the heart-rate monitor to the motherboard.
    • Using the spudger and your fingers, gently lift the motherboard from the band socket.
    • You should feel a "pop."
  10. Microsoft Band Motherboard Replacement: 手順 10、 3の画像 1 Microsoft Band Motherboard Replacement: 手順 10、 3の画像 2 Microsoft Band Motherboard Replacement: 手順 10、 3の画像 3
    • Gently flip the motherboard so that you are viewing the motherboard from underneath.
    • Using the tweezers, gently detach the golden connector from the back of the motherboard.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Takuma Yonebayashi
メンバー登録日: 01/28/15
326 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G34
4 メンバー
6のガイドは作成済み
コメント 1 件
Thanks! that was useful
ASDF ASDF - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 20
今までの合計 2,950
