メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Merch Source Projector Entertainment II Cooling Fan Replacement
必要な工具と部品
  1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 手順 1、 2の画像 1 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: 手順 1、 2の画像 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    FixBotに聞いてみる
    コメントを追加
  2. Merch Source Projector Entertainment II Cooling Fan Replacement: 手順 2、 1の画像 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
    FixBotに聞いてみる
    コメントを追加
  3. Merch Source Projector Entertainment II Cooling Fan Replacement: 手順 3、 2の画像 1 Merch Source Projector Entertainment II Cooling Fan Replacement: 手順 3、 2の画像 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
    FixBotに聞いてみる
    コメントを追加
  4. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 手順 4、 2の画像 1 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: 手順 4、 2の画像 2
    • Locate the 80 mm fan and slide upward straight out of the housing.
    FixBotに聞いてみる
    コメントを追加
  5. Merch Source Projector Entertainment II Cooling Fan Replacement: 手順 5、 2の画像 1 Merch Source Projector Entertainment II Cooling Fan Replacement: 手順 5、 2の画像 2
    • Unsolder the red and black connections off of the motherboard.
    • If there are zip ties around the cables, they will need to be cut to remove the fan.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections will get very hot. Never touch the iron with your hand.
    • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
    • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Stephanie
メンバー登録日: 01/08/15
282 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S18G3
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 21
今までの合計 2,804
