はじめに
From fluid leaks, to aged suspension components, to rust there are many items, big and little, to check when you are considering buying a W123 Diesel. You're very unlikely to find one without any maintenance or repair items to address so don't let this deter you. Simply understand that knowledge is power when it comes to buying an older used car. You'll better know what you're getting in to and you may have some better wiggle room when negotiating price.
Please note that the vehicle used as an example in this guide is a non-turbo diesel engine. The majority of this guide will apply to turbo diesel and gas engine cars as well. However, be sure to do some research about the key differences before going shopping!
This guide will be separated in to five sections:
Vehicle walkaround, exterior check
Interior check
Under-hood check
Under-vehicle check
This guide does not include the test drive.
Vehicle walk-around and exterior check
As you walk around the vehicle inspect each body panel for dents, dings, obvious paint blemishes or rust spots, etc.
Also check for missing or damaged trim pieces and emblems.
Ask if the vehicle has been repainted, when it was done, and whether the color was changed. If the vehicle was repainted pay special attention for signs of a sub-par paint job such as over-spray on trim or within the wheel wells, excess "orange peel", places where the color looks faded or doesn't match, etc. Examples:
Fading paint where it was applied poorly
Over spray, the rubber windshield seal was painted over
Check along the bottom edge of the car for rust; you may need to squat down low to see it.
Pay special attention to the area around the jack holes; in northern climates salt collects in and around these creating rapid and severe rust.
Check for rust up under the fender wells especially on the side where the battery resides up front. Battery fumes will speed up rusting there.
Also check for rust where the fenders meet the doors. Water drains are located there. If they clog water can collect creating rust problems.
Check for rust at the bottom of the inside of each door, you may need to push the trim out of the way
Open all of the doors. They should open smoothly and quietly. There should be no squeaks, clunks, or grinding noises. Note that on this door there is a slight "clunk" at about the mid point. This door check strap needs to be cleaned and lubricated.
Close each door; it should close with a solid "thump".
You should not have to slam the doors to get them to close.
The front doors have door check straps that have two stop positions. Check to see that the check strap holds the door open both at the halfway point and the full open point.
The rear doors only have one stop on the check straps. The check strap should hold the door open at the full open position.
Open the trunk. If the vehicle has central locking it should be unlocked if the rest of the car is as long as the trunk lock is in horizontal position.
The trunk should stay locked if the lock is in the vertical position even if the rest of the car is unlocked.
If the owner will allow, pull up the plastic covers in the wells on either side of the trunk and inspect for rust. Picture shows trunk with plastic cover removed.
Open the fuel door. There should be a sticker inside noting tire pressure specifications.
Check the fuel filler neck seal for dry-rot or other damage.
Take off the fuel cap and check the seal.
If the car has central locking ask the owner to lock the car while the fuel door is open. A small pin should extend in to the fuel filler opening; this is the gas door lock.
Ask the owner to operate the power antenna, or do it yourself using the switch inside the car. It should move smoothly and without excess noise.
Watch and see that it also operates properly during your test drive. It should raise when the car is started, and it should lower when it is turned off.
At the front of the car check the turn signals and head lights, aks the owner to operate them. Also check that the high-beams work and that the fog lights work.
It is typical for the old plastic turn signal lights and the plastic surrounds, also known as "doors", around the headlights to be covered in small cracks otherwise known as crazing.
The headlights on U.S. cars, however, are sealed beams in a glass housing. The fog lights are glass too. These should not be cracked. Small rock chips are typical.
Interior check
Sit in the driver's seat. This seat gets the most use, and will be the most worn. It should be firm but comfortable. If it sags too much, it likely has one or more broken springs.
While sitting there take a look at all of the wood trim. Check for areas where it's coming loose, or where it's cracked, the finish is coming off, or it is missing entirely.
Note that loose trim can be easily re-glued in most cases, while cracked or missing trim can be expensive to replace.
Check for ease of movement of all of the vent pods in the dash. They should move easily. Turn the knob to see if they open and close properly.
Move the combination switch up and down, for right and left turn signals respectively, and then push it away from you for high-beams. It should firmly move in to each position and stay there without any slop. Then pull it towards you for high-beam flash; it should spring back to the center position when you let it go.
Press the center pad on the steering wheel to test the horn.
At this point, ask to start the car.
If the vehicle is a diesel don't forget you'll have to let the glow plugs cycle before starting the engine.
Turn the key to the run/glow position, just left of the start position, and let the glow plugs cycle. The glow plug light should turn on. Depending on the type of plugs as well as the outside temperature the light should stay on anywhere from 5 to 30 seconds or so.
Check that the other warning lights come on at this time.
Check to see that the gas gauge moves up from Empty to the current level.
Start the car once the glow light goes out. Unless it's unusually cold the car should start quickly on the first crank.
When the engine first starts the oil pressure gauge should jump up to its highest point almost instantly.
Now that the car is running it will be easier to test a number of the car's accessories.
Begin by turning on the car's climate control. If the car has automatic climate control take some time to run it through the various settings such as Auto Lo, Defrost, etc. Move the temp wheel from cold to hot and back again to see if the vents change from upper to lower vents.
Under-hood check
Check the connections on the battery for excess corrosion.
Check around the battery for obvious rust. If you see any, ask to remove the battery for a better look at the tray. If it's rusty assume the fender is rusty underneath it. We'll check the fender from below during the under-car check.
Take a look at the wires and vacuum lines next to the battery and look for damage from exposure to battery fumes. On this car, someone sprayed over these lines with some kind of black goop perhaps to try and protect against this.
Consider bringing a multimeter with you to test the battery and alternator, it's very easy to do.
Review the guide on this process before hand so you are prepared. Click here to see the battery and alternator test guide.
Remove the oil cap with the engine running and monitor the "blow-by".
See the basic blow-by test guide beforehand for help with this.
Open the power steering pump reservoir lid.
Check the fluid level, and condition of the fluid.
The fluid may be red, yellow, or clear depending on the kind used but in any case it should be fairly clear and clear looking.
This pump has very dirty, old red automatic transmission fluid and is also low on fluid. The steering pump groaned and was hard to turn.
This pump has fresh new clear power steering fluid and was quiet and smooth because of it.
Now check all of the fluids that you haven't checked yet. Here are some guides to help you:
Checking coolant level in your naturally aspirated diesel Mercedes W123
How to check the coolant level in your Turbo Diesel Mercedes W123
Under-car check
Safely jack up the car as shownin the jacking guide. Of course, get the owner's permission, and even better, get their assistance.
Starting at the front of the car, just behind and under the radiator, check the two transmission cooling hoses. This is the updated style with protective spring covering. This protects them from road debris and the A/C compressor belt.
Check the lines for weeping, and if the old style is present, check for cracks, cuts, etc.
When the inspection is complete you will be ready to take a test drive. Watch for any odd handling, unexpected noises, etc. Once you're done with the test drive you'll be prepared to make a decision on your potential new W123, and you can negotiate for a good price.
36 の人々がこのガイドを完成させました。
6 件のコメント
This site is great! This is an awesome guide.
Awesome Sauce!
Thanks! Do you know where to get tips on repairing this beautiful vehicle?
Perfect, exactly what I was looking for.
Chaz Maldy - 返信
Nice share! thanks for the post
Thanks for the sharing valuable information.
