はじめに
This guide applies to earlier style non-turbo diesel engines that do not have a translucent plastic overflow tank for observing coolant level. On these cars the only way to check the coolant level is to remove the radiator cap.
必要な工具と部品
Before proceeding very carefully check that the coolant temperature is low enough to safely check the coolant level.
To do this use your hand to carefully check and see how hot the radiator cap is. It should be cool to the touch. If it is hot, or even warm, it is best to wait. If you have recently driven the car it can take several hours before the coolant has cooled enough to check the level.
If the coolant is low it should be topped off with half distilled water and half coolant, if using full-strength concentrated coolant.
Never mix coolants. If you find your cooling system is filled with green coolant top it off with the same type of coolant but plan to change the coolant out and flush the system in the near future.
8 の人々がこのガイドを完成させました。
2 件のコメント
I have a 1984 W123 300D, which doesn't have a coolant recovery bottle. I would like to have one fitted. Where is it suppose to be? I mean how close or far from the radiator? And at what level/height as compared to the radiator? I believe the level/height of the radiator cap and the bottle cap has to be the same.
