メインコンテンツにスキップ
Master and Dynamic MW50 Motherboard Replacement
必要な工具と部品
  1. Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: 手順 1、 3の画像 1 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: 手順 1、 3の画像 2 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: 手順 1、 3の画像 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Motherboard Replacement: 手順 3、 1の画像 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Motherboard Replacement, Motherboard: 手順 4、 3の画像 1 Master and Dynamic MW50 Motherboard Replacement, Motherboard: 手順 4、 3の画像 2 Master and Dynamic MW50 Motherboard Replacement, Motherboard: 手順 4、 3の画像 3
    • Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
    • Move the side cover off to the side.
    • The black cable connected to the motherboard from the side cover can be gently pulled off from the motherboard side. It isn't soldered on.
  5. Master and Dynamic MW50 Motherboard Replacement: 手順 5、 1の画像 1
    • Desolder all the wires connected to the motherboard.
    • Refer to this picture for soldering the wires on the new motherboard.
  6. Master and Dynamic MW50 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the two 2mm screws holding the motherboard in place.
  7. Master and Dynamic MW50 Motherboard Replacement: 手順 7、 1の画像 1
    • Replace with new motherboard.
終わりに
To reassemble your device, follow these instructions in reverse order. You may want to use the picture from Step 5 to correctly re-solder your device.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ryan Chan
メンバー登録日: 01/24/19
297 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019人のメンバー
CPSU-WHITE-W19S1G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 323
