はじめに
This guide will teach you how to disassemble your Martian Victory Smart Watch, so that you can replace the Analog Watch Face. You might need this guide as your watch face is most likely broken and needing to be replaced. Repairing the watch face will allow the time to be seen easier, along with all the other features on the smart watch. Being able to solder might be useful in fixing your watch, but following the directions will help you with all you need.
必要な工具と部品
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
