メインコンテンツにスキップ
MapKeyboard Tutorial
    • 1. When one of your keyboard's keys is broken, you don't want to spend a lot of money to replace the entire keyboard because of one key
    • 2. You can use a software called "MapKeyboard"
    • 3. Start the software and select the key you will use to replace the broken key
    • 4. Select "ReMap selected key to" and select the broken key "G"
    • 5. Click on "Save layout" and the laptop will restart
    • 6. After restarting, you will find that the key you set can be typed with “G” so that you can continue to use your keyboard without changing it
    • 7. If you want to restore the layout of the keyboard, you can start the software again, click on "Reset keyboard layout"
    • 8.After the restart, it will be restored
終わりに
作成者
3人の作成者と共同で作成されました。
Laptop
メンバー登録日: 05/29/18
1,021 ポイント
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,229
